1998 Chevy Cavalier Neutral Safety Switch? Really?
SEATTLE_CHICK
Transmission problem
1998 Chevy Cavalier 4 cyl Two Wheel Drive Automatic 136k miles
Last summer I had the transmission rebuilt; recently, it has not been shifting as smoothly, it's been dropping abruptly (kinda like a racecar), and getting more and more noticeable. The transmission rebuild is still under warranty, so I took it back in. The mechanic drove it and thought the tranny was still fine, but "maybe it's an engine problem." He was shifting in and out of "3" and "D" while driving. As I drove away, it would no longer shift into gear! Rev'd up to 3-4k RPMs and only going 20mph. I took it right back. Now he says the Neutral Safety Switch is worn out and must be replaced.
1) I thought the Neutral Safety Switch is part of the starter system. The car starts just fine, it's just not shifting on its own. (if you manually put it in 3rd it will go... but it won't go into higher gears when it's in Drive.) Does this diagnosis make sense?
2) Is this something that "just breaks" or did he break it?? It was not doing it before!
Thanks for your help.
May 20, 2010 at 7:07 AM
CARADIODOC
  • 34,412 POSTS
Hi Seattle_chick. Welcome to the forum. You are correct; the neutral safety switch is there to prevent the engine from starting when the transmission is in gear. While it is true, engine running problems can cause problems that appear to be transmission-related, your description does indeed sound like a transmission problem. Have the shop owner drive the car and give you his opinion. If they say it is not related to the work they did previously, get a second opinion from a different shop.
caradiodoc
May 20, 2010 at 8:11 AM
