1998 Chevy Cavalier Cooling light
MUDDAUBERE
  • 1998 CHEVROLET CAVALIER
  • 4 CYL
  • 115,000 MILES
Last summer my car started overheating. I was loosing water and I would not have water pressure. I replaced the thermostat and the water pump. I am now not loosing water and I have adiquate pressure. When I drive the car around town everything seems fine. When I get onto the highway or over 35 mph, my temperature begins to drop. I am getting hot air from the heater but once the temp drops below normal, the air become cold. I then proceeded to replace the thermostat again thinking I had a bad one. This did not make a difference. My low coolant light remains on even through I have enough water. I checked the water level sensor and its plugged in. Could the light and the loss of temp have something in common? I have bled the water lines for air pockets but I still loose heat at high speeds. What do I try next?
Thursday, March 12th, 2009 AT 9:03 PM
MMPRINCE4000
  • 8,548 POSTS
Still sounds like their is an air pocket in system, re-bleed the system and make sure recovery tank is full.
If problem persists, have cooling system pressure tested.
Also consider possibility low coolant sensor is bad.
Friday, March 13th, 2009 AT 7:37 AM
