Welcome to the forum, I'd have to make sure the battery has a full charge and the connections are good. After it stalls, if your saying the starter won't even crank, the purple wire at the starter solenoid should be hot with the key in the start position. If it isn't, backtrack the circuit. You may have to check feed to and from the ignition switch?
SPONSORED LINKS
Sunday, November 8th, 2009 AT 3:14 PM
