1998 Chevy Cavalier - ABS Light stays on
WARREN_S
  • 1998 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 186,000 MILES
Hello! At first, the ABS light would come on intermittenly, and if you turned off the ignition, then back on, it would stay out. Now, approx. 2 months later, it stays on all the time. Ichanged the ABS relay in the fusebox under-hood, but that wasn't it. Checked ALL fuses related to the ABS system, no luck. I passed inspection (NJ), but conditionally, with an "advisory" to have the problem remedied within 60 days, or face sanctions. I have a feeling I won't be able to find an honest enough mechanic to check the system, and have them say it's going to be a several hundred dollar job. Anybody, any thoughts?
Thanks so much!
Warren
Saturday, May 10th, 2008 AT 2:42 AM
  • 31,937 POSTS
Hi there,
I am sure that you can fine an honest mechanic. You will have to get any fault codes read, this will be a starting point, as hopefully it will be a faulty wheel speed sensor that is causing your problem. Get a code read done first.
Mark (mhpautos)
Saturday, May 10th, 2008 AT 4:06 AM
