You will need to have the ABS system scanned with a chassis scanner, most autoparts stores only scan the powertrain, so you will need to find someone with a chassis scanner.
Could be as simple as a wheel sensor, but the scanner will give you the code, which will give you the correct direction to start with.
SPONSORED LINKS
Monday, October 20th, 2008 AT 8:18 AM
