I have had my car into my mechanic twice, it is running at the borderline of hot, If I drive it over ten miles down the road, the needle goes up slowly, and stops right on the line between normal and hot, I'm scared if I drive it further than that, I will damage my engine. My mechanic has checked the head gasket with a pressure test, has checked the fans and water pump, all are working properly. This last time, I had it in, they said there were air bubbles in my radiator and upon releasing those bubbles, the car stoped overheating, now it's two weeks later, and my car is running hot again, what could be causing this problem, that they have not checked?
SPONSORED LINKS
Tuesday, February 9th, 2010 AT 8:31 PM
