1996 Chevy Cavalier radiator fluid leaking
DANIEL BRYANT
  • 1996 CHEVROLET CAVALIER
  • 4 CYL
  • 145,000 MILES
My car has a very slow leak of radiator fluid out the side of the motor and after about 30 minutes it will start vibrating the whole car and the temperature gauge goes almost to the red spot on the gauge and im wondering if I need a head gasket or can I put some fix-a-leak in it
Monday, March 24th, 2008 AT 3:53 PM
MECHANIC-IN-TRAINNING
I would suggest replaceing the head gasket even though they make stop leak products. It's not always best to add them
Monday, March 24th, 2008 AT 10:54 PM
SPADE007
  • 37 POSTS
I would check water pump the bearings are probably gone making the car vibrate. The water pump is on the left side of engine
Tuesday, March 25th, 2008 AT 9:54 PM
