1996 Chevy Cavalier Leaks Antifreeze
96CAVZ24
  • 1996 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • MANUAL
  • 120,000 MILES
Its kinda seems like it coming from the heater hoses from the housing of it. I first started smelling in through the vents and after I parked it was leaking. It has all the origanal hoses on it so I think ill start by replacing those. But I want to know what you all think it could be.
Monday, February 23rd, 2009 AT 2:13 PM
MMPRINCE4000
  • 8,548 POSTS
Have system pressure tested to pinpoint leak. The smell of coolant inside is probably a leaking heater core.
While I would also replace the hoses, have the system pressure tested, and you will probably have to change heater core.
Tuesday, February 24th, 2009 AT 9:32 AM
