Hello, does the high-mount brake lite work? Did you check for voltage at the fuses? Even if the fuse is good, if there is no feed, it won't matter. The brake fuse is hot all the time. The turn fuse circuit goes hot when you turn on the key.
The lower brake lites and turn signals use the same bulb filament, just not at the same time.
When you replaced the turn switch/multifunction, did you check the feed circuits to the switch?
SPONSORED LINKS
Tuesday, March 10th, 2009 AT 1:08 PM
