Can you tell me were the horn is it is not working can not find the fuse
ROMANJOE1
  • 1995 CHEVROLET CAVALIER
  • 4 CYL
  • 100,000 MILES
Can you tell me were the horn is it is not working can not find the fuse but checked all the fuses and nome blown but were under the hood is the horn
Wednesday, September 2nd, 2009 AT 8:55 AM
SQM
  • 6,383 POSTS
The horn is located behind the front bumper cover on the radiator core support. See diagram below.
An inoperative horn can be due to a bad relay, wiring or a bad horn itself.
Another possibility is a bad switch.
Check the relay first. It is located under the dash on the driver side (see diagram).
Check for any corrosion or burn pins.
This relay can also be tested for functionality.
If the relay is good check to see if you are getting power to the horn.
If there is no power at the connector then there is a short in the horn harness. This will require you to trace the wires to find the short. I have attached the wiring schematic below.
If there is power at the connector then the horn is likely bad and need to be replaced.
Friday, October 22nd, 2021 AT 9:19 PM
