i plugged in a computer in my vehicle and it says that it has low voltage going to my TPS senser. How do i fix the problem?
Jun 4, 2009 at 1:29 PM
BLUELIGHTNIN6
✓Experienced Mechanic
If the code was for TPS low voltage then it is most likely the TPS itself thats faulty. However, you will want to inspect the wiring to the TPS to ensure it is connected and not damaged.
