I see, did you use a testlite to check fuse circuit for voltage? Even if the fuse is good, if there is no voltage on the fuse circuit, the circuit is dead. When you first turn the key on, the lites on the dash are ignition feed, comes from the ignition switch. You may need to check feed to and from the ignition switch, for the dash.
Tuesday, December 15th, 2009 AT 2:52 PM
