1978 Chevrolet Caprice Grinding Noise
DEJJA023
my car is a rear wheel drive 1978 caprice classic 6 cylinder with 86,000+ miles. it gets stuck everywhere in the winter including flat surfaces. i have been by myself and not been able to get the car to move. the tires will spin and now, i have noticed this week that it has been grinding when i drive forward or backwards as if when breaks go bad and grind. it alson happens when i turn the car. i'm wondering if this has anything to do with the tire spinning that was done when i was stuck the many times.
i am so sorry but i do not have a credit card to make a donation with and depending on the problem, i may be really broke i'm so sorry i know how it is
Feb 12, 2007 at 9:00 PM
2CARPRO JACK
  • 11,533 POSTS
So does the noise change when brakes are applied? Or is it a constant grinding? Either way, needs to be checked out for your own safety. Cant put a price on your health
Feb 13, 2007 at 12:06 AM
DEJJA023
it does make the sound but not like it would if the breaks were gone, those were just replaced recently (in the past 4 months) it's mostly constantly. it also does this thing occasionally where when i take my foot off the gas the car seems to stop itself instead of rolling. it's almost like there is something stuck in the tire region. that doesn't happen all the time.
thank you so much for any suggestions you have as to what it may be so i know a little of what i may be paying to fix it and the garage doesn't rip me off for being a female. thanks
Feb 13, 2007 at 4:22 PM
2CARPRO JACK
  • 11,533 POSTS
Have the wheel bearings checked
Feb 14, 2007 at 1:55 AM
Suggested Repair
Have the wheel bearings checked. The grinding is mostly constant and does not match worn brakes, which were replaced recently.
Conversation Summary
The owner of a 1978 Chevrolet Caprice Classic reports constant grinding while driving forward, backward, and while turning, after the tires spun repeatedly when the car was stuck in winter. The car also sometimes stops itself when the accelerator is released. Brakes were replaced within the past four months and the noise does not sound like failed brakes. The expert advises having the wheel bearings checked for safety.
