1994 Chevy Caprice Stalls When Stopping
THEYCALLMELISSA
Please help! I have a 94 Chevy Caprice, approx mileage is 189,000, it's a 4.3L V-8, automatic. It's stalling, not when driving it, but sometimes when you stop. It's "jumping" when you are stopped and occasionally when driving down the road. It's leaking anti-freeze, but we can't tell from where. There is a little bit of black smoke coming out the exhaust. Power steering gets tight also sometimes. The fuel filter, alternator, plugs and wires, distributor are only approx 2 months old (brand new when purchased). The fuel pump is only about a year old. Any help you can give is soooooooo greatly appreciated!!!!
Thank you so much! Melissa
Oct 18, 2007 at 1:14 PM
BMRFIXIT
  • 19,053 POSTS
[quote:79425b7e84="TheyCallMeLissa"]Please help! I have a 94 Chevy Caprice, approx mileage is 189,000, it's a 4.3L V-8, automatic. It's stalling, not when driving it, but sometimes when you stop. It's "jumping" when you are stopped and occasionally when driving down the road. It's leaking anti-freeze, but we can't tell from where. There is a little bit of black smoke coming out the exhaust. Power steering gets tight also sometimes. The fuel filter, alternator, plugs and wires, distributor are only approx 2 months old (brand new when purchased). The fuel pump is only about a year old. Any help you can give is soooooooo greatly appreciated!!!!
Thank you so much! Melissa[/quote:79425b7e84]
Check the intake manifold for the antifreeze leak
And also if you have a vacuum leak
Steering is it happening when the car stalling
If not u may need a rack & pinion
Make sure you P/S fluid full
Good luck
Oct 18, 2007 at 1:25 PM
THEYCALLMELISSA
Thank you so much for your advise. No, the steering is tight occasionally when driving also, but not at higher speeds, only when slowing down to say a light, or taking off. I'll check the P/S fluid and the others that you advised. Thanks so much again!!
Oct 18, 2007 at 1:38 PM
BMRFIXIT
  • 19,053 POSTS
[quote:81c885a75c="TheyCallMeLissa"]Thank you so much for your advise. No, the steering is tight occasionally when driving also, but not at higher speeds, only when slowing down to say a light, or taking off. I'll check the P/S fluid and the others that you advised. Thanks so much again!![/quote:81c885a75c]
If the steering tighten up and loosen all of sudden you may need a rack & pinion
Good luck
Oct 18, 2007 at 1:45 PM
THEYCALLMELISSA
Thank you, you've been a great help!
Oct 18, 2007 at 1:48 PM
Suggested Repair
Check the intake manifold for the coolant leak and inspect for a vacuum leak that could cause stalling and jumping. Keep the power steering fluid full; if the steering suddenly tightens and loosens, the rack and pinion may need replacement.
Conversation Summary
A 1994 Chevrolet Caprice with about 189,000 miles stalls when stopping, jumps at idle and sometimes while driving, leaks coolant from an unknown source, emits some black exhaust smoke, and has intermittently tight power steering at low speeds. Recently replaced parts include the fuel filter, alternator, plugs, wires, distributor, and fuel pump. The expert advised checking the intake manifold and for a vacuum leak, confirming the power steering fluid level, and considering a rack and pinion if the steering tightens and loosens suddenly.
