I have a 97 Camaro Z28 that is starting to make a slight whine when I turn the wheel. It sound louder while parked than when I am in motion. The noise seems to sound like the noise you get when you turn your wheels lock to lock. It sounded like the noise was coming from up top,but it is actually coming from underneath. There are no signs of leaks around the Power steering pump or the rack and pinion. The steering doesn't seem to be any harder to turn than normal. Could the Powering Steering pump BE going bad? Thanks
May 29, 2006 at 3:46 PM
