1980 Chevrolet Camaro Driveshaft Yoke Removal Fix
UNCLEMONKY
I have a 1980 camaro with a 350 and a 4spd manual transmission... I have taken the engine out and rebuilt and am going to do the same with the transmission but I am not able to remove the driveshaft from the transmission.. How do I remove the driveshaft yoke from this transmission ?
Thank you
Aug 18, 2007 at 11:29 AM
CLY
  • 308 POSTS
The driveshaft yoke should just slide out. Remove the two retainers that secure it to the rear-end yoke and the take it loose from there and then just slide it out... I can't recall ever having one that was stuck.
Cly
Aug 18, 2007 at 10:40 PM
Suggested Repair
Remove the two retainers that secure the driveshaft to the rear-end yoke, disconnect the shaft there, and slide the transmission yoke out. It should come free rather than stay stuck.
Conversation Summary
The owner of a 1980 Chevrolet Camaro with a 350 and a 4-speed manual cannot remove the driveshaft yoke from the transmission while preparing to rebuild it. The expert says the yoke should slide out after the two retainers at the rear-end yoke are removed and the shaft is disconnected there.
