No ignition spark
JONNIELAZY
1995 Camaro, 3.4 engine, 330,000 miles. Replaced engine block and it has 52,000 miles on it. The engine started boging down and back firing, and then just shut off. I get no ignition spark on any of the plugs. I used a timming light to check it. What should I look for? Thanks Jonnie
Sep 21, 2007 at 12:39 PM
ARTMANG
  • 61 POSTS
change the whole coil pack with the ignition control module .the coils r on the icm .try getting some used ones from a junk yard.u can use m from another gm car like a buik skylark n such just make sure the wire harness is the same .doesnt have to be a camaro to use the coil pack.unless u wanna spent alot on a new set of coil packs and icm.for sure its ur icm ignition control module and coils.remember they come together screwd on the icm.
Dec 14, 2007 at 1:06 PM
