1995 Chevrolet Camaro Motor Swap
VIBRAMAN0077
I have a 1995 camaro with a 3,4 v6 motor with 160000 mile on it and I want to put a lower mile motor in it. My buddy has a motor from a 1998 camaro 3.8 v6 and I would like to know if I can use it and if the are any wiring or hook up issues. Thanks
Apr 28, 2007 at 6:43 AM
KIRBSTER269
  • 14 POSTS
it can be done but keep in mind ask your buddy if he or she has the computer for it, wiring is not going to just plug right up, wiring could be a nightmare, there are alternatives for wiring harness but expensive painlesswiring.com so you have an idea of just the harness I know because I put a LT1 in a S10 it will add up good luck
Jun 24, 2007 at 3:15 PM
SC1 RACING
  • 117 POSTS
you will be able to use your existing wire harness and computer. you may have to swap a few sensors out with the new motor but gm is pretty good and easy on interchanges. if both engines have the same injection you will have no problems other than tight sqeezes.
Jun 27, 2007 at 3:44 AM
Suggested Repair
Use the existing wiring harness and computer if both engines have the same injection system. Swap any sensors that do not match the replacement motor, and expect tight clearances during installation.
Conversation Summary
The owner of a 1995 Chevrolet Camaro with a high-mileage 3.4 V6 wants to install a lower-mileage 3.8 V6 from a 1998 Camaro and asks about wiring compatibility. A user warned that the computer and wiring may not connect directly and that an aftermarket harness can be expensive. The expert said the existing harness and computer can be used, a few sensors may need swapping, and matching injection systems should avoid major problems aside from tight fitment.
