95 Camaro 3.4 V6 Water leak
1995 CHEVROLET CAMARO
CARLUCCIJA
  • 29 POSTS
My brother and I have just replaced the radiator on our older brother's camaro. The camaro was running hot all the time. The old radiator was filled with rust and made the water pump go bad, so we replaced that as well. So his car now has a new water pump, radiator and hoses. The leak from the water pump is no longer there but now in a different spot. After filling the car with radiator fluid and water, we noticed a leak of water underneath. I had traced it to a hole in the transmission case. Actually the hole is in the Torque Convertor access cover. I also noticed water pouring out from the transmission pan, or atleast it looked as if it was coming from there. We are stumped and need help!!!
Apr 5, 2007 at 4:00 PM
LILWILLS
  • 49 POSTS
sounds like you have a leaking core plug
Apr 5, 2007 at 4:53 PM
CARLUCCIJA
  • 29 POSTS
[quote:c0e776357f="lilwills"]sounds like you have a leaking core plug[/quote:c0e776357f]
where exactly is the core plug? i haven't gone in deep with chevy's or domestic cars. I'm a classic import kind of person.
Apr 5, 2007 at 8:41 PM
LILWILLS
  • 49 POSTS
they are round holes in the engine block the coolant runs through them to cool the block
Apr 5, 2007 at 9:21 PM
