1995 Chevy Camaro leak
1995 CHEVROLET CAMARO
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
MLZK
I replaced water pump that was leaking and pressure tested system.Water pump had no leaks but water is coming out of the fly wheel cover.Does any one no what is causing this leak? Thanks
Jan 27, 2010 at 11:50 PM
TOOOMANYTOYS
  • 513 POSTS
Check the rear of the intake manifold. They have a issue with leaking where the intake meets the engine block. Best way to verify would be with pressure tester on use a mirror and light to see back of intake. Most of the time it drips down into the flywheel cover.
Jan 28, 2010 at 12:02 AM
