94 camero charging problem
1994 CHEVROLET CAMARO
OAKALLEY2
i have a 94 camaro 120k miles v6, the alt. guage showes it is charging sometimes and most of the time it goes into the red zone and the battery dies, i have had the alt. checked 4 times and every time they say it's good and i have changed the battery 4 times all the wirering looks good i have went over everything and can not find the problem. thank you
oakalley2
Nov 25, 2006 at 11:52 AM
BAREFOOTBOB88
  • 60 POSTS
I think the best thing you can do is replace the alternator, since you've spent that much on batteries it pry wouldn't hurt to try another alternator. To check the wiring throughly you need to test the continuity of the lead from the starter switch to the alternator. Another thing you might try is replacing the battery cables.
Nov 25, 2006 at 12:24 PM
