85 Camaro loses power
VAMPYRICO
  • 1985 CHEVROLET CAMARO
I have a 1985 camaro v8 carburated engine. Today I was driving down the road and suddenly my engine loses power while holding the accelerator down. And would return to normal operation when I let off the accelerator. The car would ultimately stall if I were to hold the acceleartor down. Can you guys help me out.
Thursday, March 29th, 2007 AT 8:07 PM
BURRBRIAN
  • 158 POSTS
Not knowing what carb you have or whether it's a 2 or 4 barrel my first thought would be to check out the acc. Pump and see if it's working right. Also sounds like the float level might be too low starving the motor for gas when you try to accellerate. Your fuel pump may also be getting weak and not supplying enough fuel to run beyond part throttle. Start at one end of the system and work your way through to the other end- I think somewhere in there you will find your problem. Just my.02 worth.
Hope any of this helps you out some. :Roll:
Sunday, April 1st, 2007 AT 10:21 AM
VAMPYRICO
  • 27 POSTS
Thx for the help, im buying a new carb. Its a 4 barrel carb. A q-jet. Acc pump is fine. But I do think that the carb is starving of fuel. Dont wanna rebuild to find out. So, new carb. Lol. I really do appreciate the help tho.
Sunday, April 1st, 2007 AT 10:11 PM
