2001 Chevy Camaro Engine temp gauge
137,000 MILES • 6 CYL • 2WD • MANUAL
BRANDONMC
My camaro had the factory 195' thermostat running 205'. I don't like high temps, so I installed a 165' thermostat. I did that on 2/12 and yesterday, 2/20, the gauge stopped working. It won't go up or anything, its just sits below 0'. The electric fan is constantly running; I've flushed the radiator and motor and changed the antifreeze, but still don't know why its not working.
Feb 21, 2010 at 2:33 AM
JDL
  • 16,098 POSTS
Just my opinion, I'd leave the original thermostat in it. 205 isn't too hot. Check for trouble codes, generic as well as manufactuer specific. See if a code points at anything? Maybe an issue with coolant temp sensor?
Feb 21, 2010 at 3:51 AM
