HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Camaro
Suspension
Strut
2000 Chevy Camaro
ABNMED
MEMBER
2000 CHEVROLET CAMARO
6 CYL
2WD
AUTOMATIC
115,000 MILES
HOW CAN I TEST THE STRUTS
Friday, May 30th, 2008 AT 7:42 PM
BLACKOP555
MECHANIC
Bounce one corner of the vehicle at a time. Once the vehicle is bouncing good step back, the vehicle should stop bouncing and return to the original ride height after you step back, if not they need overhauling.
SPONSORED LINKS
Friday, May 30th, 2008 AT 9:33 PM
Please
login
or
register
to post a reply.
Related Strut Content
Lower Control Arm Right Side
I Have A 1995 Z28 With A L S1 Motor I Am Having Troble Getting The Lower Control Arm Off. Do You Put The Fork Under The Control Arm Or...
Asked by
jacrum
1 ANSWER
CHEVROLET CAMARO
VIDEO
How to Replace Front Coil Over Struts RAM
Instructional repair video
GUIDE
Shocks and Strut Inspection
A shock or strut controls movement when a car is driven into a corner or over bumps. These units are comprised of shock oil, dampening valves, a piston, main seal, main body...
1995 Chevy Camaro 55mph And Up It Wiggles
This Car Is Crazy Fast, But When I Put It On The Freeway You Can Even See The Headlights Moving Left To Right A Few Inch's. I Just...
Asked by
Jasonosborne1974
1 ANSWER
1995
CHEVROLET CAMARO
Camaro Suspension
I Am Changeing The Rear Shocks On My 1985 Camaro Z28 V8 5.0l And I Dont Know Were The Top Bolts Are For The Rear Shocks Are They In The...
Asked by
violation3
1 ANSWER
CHEVROLET CAMARO
SPONSORED LINKS
How to Replace Strut and Coil Spring Assembly
Shock Absorber Replacement
Online car repair manuals
