1998 Chevy Camaro transmission swap
120,000 MILES • V8 • 2WD • AUTOMATIC
SHON HURT
i have pieced this car together and when i put the automatic transmission in it didnt want to shift out of second gear. had it rebuilt and still had same problem. found a used one and still had same problem. the plug for the speed censor is not the original one with different color wiring but it plugs in. my question is could that be the reason for my troubles or is there something else electrical that could be causing it not to shift out right
May 13, 2008 at 10:51 AM
PRODRIGU
  • 26 POSTS
Check your map sensor, if thats not working properly or at all the vehicle will not shift properly or at all. Check your local library for wiring schmatics on the transmission, the colors on the wiring don't always match but make sure they are going to the correct terminal on the PCM
May 18, 2008 at 4:01 AM
