1989 Chevy Camaro Circuit fault in vehicle speed sensor
1989 CHEVROLET CAMARO
67,521 MILES • V8 • 2WD • AUTOMATIC
BDOG3691
what does this mean and how do i fix it?
Jan 9, 2010 at 12:04 PM
ERNEST CLARK
  • 1,730 POSTS
either your VSS is bad, or there's a short/break in the wiring or connector.
OPERATION:
The VSS is located on the transmission and sends a pulsing voltage signal to the ECM which is converted to miles per hour. This sensor mainly controls the operation of the TCC system, shift light, cruise control and activation of the EGR system.
REMOVAL & INSTALLATION:
Disconnect the negative battery cable.
Raise and safely support the vehicle.
Disconnect the VSS electrical wiring.
Remove the retaining bolt.
Have a clean container to catch the transmission fluid and remove the VSS.
Remove and discard the O-ring.
To install:
Lubricate a new O-ring with a thin film of transmission fluid. Install the O-ring and VSS.
Install the retaining bolt.
Connect the electrical wiring.
Lower the vehicle.
Connect the negative battery cable.
Refill transmission to proper level.
If I've helped you, please "Vote" for me. I'm trying to become a full-time moderator on this forum. Thanx!
Jan 13, 2010 at 1:22 AM
