1978 Chevy Camaro I want to swap my transmission
1978 CHEVROLET CAMARO
100,000 MILES • V8 • 2WD • AUTOMATIC
HUESTIFER
I have a 1978 Camaro that has a 1991 Caprice engine in it (5.7 TBI FUEL INJECTION) the original Transmission just went out. and I found a really inexpensive Barrly used (8000miles) Transmission that i think might work (TH4L60E FROM 2001 S-10 TRUCK
4 SPEED AUTOMATIC, ELECTRONIC 700R) the TH4L60 Fits in the 1991 Caprice but the electronic version is for a later model caprice.
so my question is if my engine fits the original trany then could I replace the original with this one?
also the transmission I found Is Electronicly controled and OBD2 and the 91 Caprice engine is OBD1 so would that be an issue?
Feb 3, 2008 at 9:43 PM
JOHNYPHANTOM
  • 37 POSTS
your best bet would be to find an older 350 or 400 trans , it should bolt up to engine just fine and you wont have all the electronics to worry about . only thing you need to be sure of is length of transmission compared to what you have
Feb 7, 2008 at 10:24 AM
