1998 Chevy Camaro INSERT REAR SUSPENSION OIL
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
NAVIGATOR
JUST IF U CAN HELP ME, LET ME KNOW HOW I CAN PUT OIL IN THE REAR AXAL IT HAS A HUMMING NOISE IMTHINK IT NEEDS OIL
THANK YOU ,
DAVID
Feb 12, 2009 at 3:18 PM
KYTERRYLEE
  • 8 POSTS
There is a check and fill plug at the front of the differential near the yolk. Remove the plug and fill with 75/140 gear oil. If you are not familiar with this procedure you should take it to your local automotive repair facility. It shouldn't cost very much.
Feb 15, 2009 at 12:48 PM
