1997 Chevy Camaro Water Pump Bad?
90,000 MILES • V8 • 2WD • AUTOMATIC
P RINDGE
  • 9 POSTS
LT1 Motor - was overheating. Found temp sensor in head broken - replaced (GM part). Bled system upon refill of coolant on a hill (nose up) using the bleeder valves - felt confident. Started it up with heater on waited for thermostat to open to observe flow, lots of bubbling out of coolant and continued to use bleeders. Never saw flow (even from the little hose from the pump to the radiator neck)and no heat. Fans came on and dash guage indicated hot but not red zone. If reved a little, dash guage would fluctuate down quickly and then rise quickly. Placed the cap on and there was lots of bubbling in the overflow tank and the thermostat housing bleeder blew steam off like a tea kettle - shut it down. We have the long thermostat as required. I don't think it is the thermostat b/c we do not have heat and the little hose would still have flow. I think water pump. Anybody agree?
Stumped and frustrated.
Phil
Aug 23, 2010 at 5:36 AM
WRENCHTECH
  • 20,760 POSTS
Sounds like you may have a blown head gasket. I suggest you have chemical tests done to determine if that is the case or not.
Aug 23, 2010 at 6:17 AM
P RINDGE
  • 9 POSTS
Thanks Wrenchtech. If the head gasket was bad wouldn't we still have heat and see flow in the radiator neck? I was thinking that these 2 factors eliminated the head gasket as an issue. The chemical tests you mention - what and how do they check for?
Phil
Aug 31, 2010 at 6:46 AM
WRENCHTECH
  • 20,760 POSTS
No, it's very common to lose heat with a blown head gasket because you are pumping hot combustion gases into the cooling system. If the heater core is full of air, you will have no heat.
The best chemical test is done with an exhaust analyzer. You hold it over the radiator and it sniffs the coolant for hydrocarbons.
Aug 31, 2010 at 7:00 AM
P RINDGE
  • 9 POSTS
Thank you for the explanation - I did not know this.
Phil
Sep 2, 2010 at 11:47 PM
WRENCHTECH
  • 20,760 POSTS
Your welcome
Feedback s appreciated
Sep 2, 2010 at 11:53 PM
