2001 Chevy Camaro
2001 CHEVROLET CAMARO
150,000 MILES • 6 CYL • FWD • AUTOMATIC
TOBY3674
I have changed water pump and thermostate is still over heating and oil pressure keeps at a low
Jul 15, 2009 at 2:25 PM
LOUT5369
  • 217 POSTS
Check your electric fans on the radiator,run the car,fans should kick on by 230 degrees,if not turn a/c on, fans should be commanded on by computer for a/c request.if they still don't come ,check fuses,if you find a blown fuse,shutoff engine try to manually spin fan,fan maybe frozen,BE CAREFUL,there isn't a car in the world worth getting hurt for.If fan is frozen,install new fan,replace fuse,if not have computer scanned,to check if computer is commanding fan on.Good luck
Jul 22, 2009 at 11:45 PM
