1996 Chevy Camaro INLET HOSE
DOVE47
  • 1996 CHEVROLET CAMARO
Heater problem
1996 Chevy Camaro 6 cyl Two Wheel Drive Automatic
I WANT TO FLUSH MY COOLANT, BUT I AM UN SURE WHICH IS ILET HOSE
Tuesday, January 13th, 2009 AT 7:04 PM
TEAG
  • 158 POSTS
The hose you want to hook your flushing T up to is the one on the far passenger side. Thats the best bet but if you cant get good access to it. You can hook it into any heater hose. Just make sure to let it run for a good amount of time in order to flush everything out. Also make sure you have the heat on full blast so that the heater core gets flushed also. If at all possible. Use hot water when flushing. Good luck :)
Friday, February 20th, 2009 AT 11:38 AM
