1996 Chevy Camaro
1996 CHEVROLET CAMARO
58,000 MILES • V8 • 2WD • AUTOMATIC
CMAN1224
Any idea what would make the engine start misfiring after it gets warmed up already changed coil
Jun 22, 2009 at 12:01 PM
SERVICE WRITER
  • 9,123 POSTS
Many possiblilities. Plugged converter is one of many possiblilities.
I would start with a code check on the pcm to see what is in there. Check fuel pressure and for spark when the problem is happening to start narrowing this down. The codes may give some insight.
Post what you find.
Jun 22, 2009 at 12:17 PM
CMAN1224
PO 300 is only code
Jun 22, 2009 at 12:23 PM
SERVICE WRITER
  • 9,123 POSTS
Multiple misfire code.
5.7 motor?
HAve you looked at the cap and rotor? Seen a fair amount of them be a problem. I would replace it with a delphi if it is suspicious.
Best trying to determine if it is spark related and not fuel related. Test while the problem is happening.
Have you been losing any coolant?
May want to try a compression test on the cylinders after the motor is warm. That will give you a chance to see what the plugs look like and see if any abnormalities are present at the same time.
Jun 22, 2009 at 10:06 PM
CMAN1224
Haven't got to cap and rotor yet not loosing coolant
Jun 23, 2009 at 8:15 AM
SERVICE WRITER
  • 9,123 POSTS
Scoping the spark would be good. Find out where the higher count is.
If you can't check this, get a look at the cap and rotor.
Can you check fuel pressure?
Jun 23, 2009 at 12:46 PM
