1995 Chevy Camaro Radiator
KICKER2
  • 1995 CHEVROLET CAMARO
  • 6 CYL
  • 140,000 MILES
Smells like burning radiator fluid, always runs hot when idleing, having to keep filling with water but there is no leak underneath the car. I have changed the thermostat but is still doing it. Any suggestions on what the problem could be.
Wednesday, September 8th, 2010 AT 4:51 PM
WRENCHTECH
  • 20,761 POSTS
I can't tell you. You are going to have to pressure test the cooling system to check for leaks. Don't assume it will leave a puddle if it's leaking. Also with the history of overheating, at this point it could have a damaged head gasket from the heat.
Wednesday, September 8th, 2010 AT 6:14 PM
