1996 Chevy Camaro radiator is mysteriously leaking
1996 CHEVROLET CAMARO
120,000 MILES • V8 • 2WD • AUTOMATIC
SHEDIVY
i keep putting fluid in, andf it keeps going away
i dont see any on the ground
i guess i should fill it up with fluid, then get it up to temp on a dry surface, see what happens
it's making me crazy
i suppose i could have a leak near the radiator and it dries before it hits the ground
has anyone seen this isssue? maybe it is a known problem
thanks
david
Jan 30, 2009 at 4:02 AM
  • 31,937 POSTS
Hi there go get the cooling system pressure tested hot, this will show up any minor external coolant leaks, and get the pressure cap tested as well, this will take all of about 5 min to complete.
mark (mhpautos)
Jan 30, 2009 at 11:42 PM
