1995 Chevy Camaro need help. Have to fix it today
DAWSON18
  • 1995 CHEVROLET CAMARO
Engine Cooling problem
1995 Chevy Camaro 6 cyl Two Wheel Drive Automatic
i can drive my camaro to the store and it does fine. It wont start back up until its cooled all the way down. Could this be a sensor or something even more complicated.
Saturday, December 5th, 2009 AT 12:08 PM
Do below might lead you to somewhere
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Saturday, December 5th, 2009 AT 6:51 PM
