1995 Chevy Camaro connector-tempsenser/senser-radiator cool
1995 CHEVROLET CAMARO
188,000 MILES • V8 • 2WD • AUTOMATIC
RONALDO JIMENEZ
i pulled the connector-coolant senser and senser-radiator coolant level of the radiator and place the same ones back now my low coolant indicator lightcomes on and my radiator pops and over heats which two parts need replacing or what needs to be done to fix this problem
Jul 27, 2010 at 1:29 AM
HMAC300
  • 48,601 POSTS
if you hear a popping sound when it overheats that is usually the thermostat that is bad. But when it overheats, shut it off and unplug the fan. Then place your hand on the radiator in different places and if it feels cold anywhere then the radiator is bad as well...
Aug 2, 2010 at 11:40 AM
