1996 Chevrolet Camaro Coolant Leak
ADRIANNESUZ
My 96 chevy camero V6 (109,000 miles) almost overheated a few days ago and I noticed that I have a small coolant leak. I can't see where it is though. I replace the liquid, however, when I drive it, large amounts of coolant seem to disappear in a short amount of time leading to my warning gage rising almost into the red on almost every drive. And the last drive, my service engine soon light came on. Anyone have an idea as to what could be the problem and how much it might cost me? :( Thanks.
Jul 2, 2007 at 8:26 PM
E40WATER12
  • 522 POSTS
If you got an auto zone parts store near you, U can get the trouble code scanned, Then fix the part thats causing the problem, U dont want to keep having youre car overheat, Cause you will crack Or blow cyl hd gasket, Which could cost you $1500 in repairs.
Good Luck.
Jul 2, 2007 at 10:25 PM
YZFRIDER
  • 7 POSTS
If you can't see it in the engine compartment, have you tried looking inside the car? My 86 Z28's heater core failed and started dumping coolant into the vents and dash until it started leaking onto the passenger's side floor. Of course, the smell would probably be sweet smelling and if you use your defogger setting the windows will probably actually fog up if the heater core is leaking. You might want to pry around the passenger's side dash to see if that's where you're losing it.
Also, have you checked your oil? If you blew a head gasket, you may be leaking coolant into other parts of the engine.
Aug 6, 2007 at 12:40 PM
  • 75,988 POSTS
The best approach is to have it block/pressure tested-its leaking somewhere when its pressurized it will come out where its leaking from. Continued driving it, when the block blows its gonna be more than 1500 deniros.
https://images.2carpros.com/forum/automotive_pictures/12900_old_man_drinking_2.jpg
Aug 6, 2007 at 3:48 PM
Suggested Repair
Have the cooling system pressure-tested to find the leak, scan the service engine soon code, and check the heater core plus the oil for coolant contamination. Avoid driving while it overheats to prevent head-gasket or engine damage.
Conversation Summary
A 1996 Chevrolet Camaro V6 with about 109,000 miles nearly overheated, has a hard-to-see coolant leak, loses large amounts of coolant while driving, and later showed a service engine soon light. Replies recommend scanning the code, pressure-testing the cooling system, checking for a leaking heater core, and inspecting the oil for signs of a head-gasket leak. Continued overheating could lead to much more expensive engine damage.
