1995 Chevy Camaro Camaro engine trouble on high rpms
60,000 MILES • V8 • 2WD • AUTOMATIC
ACROCK21
hello, i have a 95' camaro Z28 .
its got more than just one problem.
When i step on the gas and the rpms get up to the 4,200 - 5,000 rpm range the car kinda bogs down and starts making what sounds like a back fire sound. but she loses her power till you let off the gas and i dont understand this . but even when im reving her up it does the same thing. it died for like a year but finally got the thing started again so its kinda confusing just what the problem is, if it sounds familour id love to know.
also dont know if it has anything to do with it or what but one day i started it and a strange clicking noise was coming out of the tail pipes
also sometimes when its running it makes a clicking noice that sounds electical next to the fuse box under the air filter area.
also under the car is a bunch of oil all over like the bottem of the engine and the tranny area its just caked on there.
Mar 29, 2009 at 11:06 AM
RANGERDANGER17
  • 224 POSTS
first problem sounds like its in the fuel
maybe a clogged fuel filter
the clicking noise is the internal parts of the muf or cat breaking down if these parts clog the air flow out the engine will back fire and move slow the big sign of that is the cat or muf getting red hot after only a few min of runnin 1-2 ,min
the last on is normal
Mar 30, 2009 at 1:07 PM
