1995 Camaro RS Problem
PTONY
I have this problem only when im taking off in first gear. Something is rattling somewhere under the hood and I cant find out what it is because the vehicle has the be taking off in 1st gear in order to hear it. So my question is, what could it possibly be? It doesnt make that rattling sound when im stopped, in neutral and rev it up. Only when I'm taking off, and only in first gear. Hopefully its not my tranny? That leads to my other problem... say for instance im driving and I have to let off the gas pedal to slow down a bit, but as I push down on the gas again to accellerate, my shifter and tranny shakes. What could that be? :(
Jan 21, 2006 at 6:04 PM
PALCO
  • 83 POSTS
have you tryed to do a second gear start? and later in your post it sonds like a engine and/or tranny mount getting worn out. good luck
Jan 22, 2006 at 3:20 AM
KAZOO2281
  • 12 POSTS
sounds like a motor mount i have an 98 camaro rs 350 where under initial load from start it would make a popping noise
Jan 22, 2006 at 10:16 AM
