1994 Chevy Camaro Idle problem
1994 CHEVROLET CAMARO
FIREBALL20
Engine problem
1994 Chevy Camaro 6 cyl Wheel Drive Type unknown Automatic 161773 miles
when the weather is cold, I'll crank the car, it holds an idle for a moment, then it dies...I have to hold the gas pedal til it warms up a bit, then it will be fine. I have replaced the TPS and that fixed the original problem of not holding an idle at all...In recent weeks I have also replaced the egr valve, a bad coil, crank shaft posit. sensor, fuel filter......I took my car to a mechanic and he hooked up the computer..he said the egr valve was bad....I have spent more money than I care on bad advise....an auto zone employee was of bigger help as he suggested the throttle posit. sensor....that at least help a great bit....can you please help me? Thank you Trish[img:fc0d4b4a28]http://www.2carpros.com/forum/automotive_pictures/147196_Trish_1_1.jpg[/img:fc0d4b4a28]
Jan 22, 2008 at 9:16 PM
You need to have the coolant temperature sensor tested-its job is like the old carb. choke system-it provides fuel enrichment during inital cold starts.
When the car fires up the idle air control valve controls the idle-might want it clean out and the passages/throttle plate/body.
Jan 23, 2008 at 12:23 AM
