1994 Chevy Camaro 94 camaro starts then dies please HELP!
SHADOW94
  • 6 POSTS
1994 Chevy Camaro 6 cyl Two Wheel Drive Automatic 90k miles
94 camaro starts then dies i have it hooked up to a push button starter from the battery to starter.When i turn the key foward i get 1 click and thats it with the button it fires up but dies it wont run for 2 seconds its getting spark and fuel.Replaced spark plugs/wires starter altenator fuel filter battery and battery cables. I hope someone can figure this out.
Oct 12, 2009 at 4:53 PM
BILLYCAMARO
not sure why you put in a push bottom but sounds more like a short in the wires if the staarter was just replaced when it was doing this the push bottom might be going bad also
Oct 26, 2009 at 4:52 AM
SHADOW94
  • 6 POSTS
I hooked the push button up to kinda by pass the ignition because when i turn the key foward i just get one click from under the dash the push button works but it shuts right off i dont what it is i had so many mechanics look at it but no one seems to know if you have any ideas please help me and how do you check for a short in the wires? And thank you
Oct 28, 2009 at 5:19 PM
REDNEKWIZARD
  • 30 POSTS
Did you take all of the wires off of the battery side of the starter.
if not try unhooking those and connecting them directly to the battery, that was one of the issues on my 86, it wouldnt start until i isolated the starter, now the only wires to the starter is the main battery cable and the wire for the push button.
Nov 1, 2009 at 1:01 PM
REDNEKWIZARD
  • 30 POSTS
[quote:571459773f="rednekwizard"]Did you take all of the wires off of the battery side of the starter.
if not try unhooking those and connecting them directly to the battery, that was one of the issues on my 86, it wouldnt start until i isolated the starter, now the only wires to the starter is the main battery cable and the wire for the push button.[/quote:571459773f]
sorry hit submit too soon.
If it starts after you isolate the starter then you have a short in one of the fusible links or in the ignition or alternator wires.
Nov 1, 2009 at 1:04 PM
SHADOW94
  • 6 POSTS
isolated the starter like you said it starts but shuts off within 3 seconds and i tested the 2 whit wires with an orange cover coming from the steering column and it has no ohms reading but the ones from the computer to the column has a ohm reading would a faulty key lock cylinder keep it from staying started cause everything else with the ignition system is new except that
Nov 7, 2009 at 6:09 PM
REDNEKWIZARD
  • 30 POSTS
There might be someting wrong with the ignition relay then, mine was located on top of the steerng column, i replaced it and it stays started now but my starter is still isolated, that way if it doesnt start i know right where to look.
You might have to drop your steering column to get to that box, i did and it was a pain but that was one of the major issues.
good luck.
Nov 8, 2009 at 6:39 AM
SHADOW94
  • 6 POSTS
I'll try it when i get the car back its in the shop now.For some strange reason they dont know whats wrong with the guy said he's having someone else to look at it tommorow so i'll give him till the end of this week then i'll go back to working on it myself.And do you think a diagnostics test would help?
Nov 9, 2009 at 3:58 AM
SHADOW94
  • 6 POSTS
I just remembered my car doesnt have a starter relay it has a solenoid wich is new do you know where the vats box is or where i could get one.
Nov 9, 2009 at 4:29 AM
REDNEKWIZARD
  • 30 POSTS
If you wanted to try and save some money i'd go to a pick a part salvage yard and look for the newest one in your f-body line and see if you can't get one from there or just look it up at your favorite part store online.
Nov 9, 2009 at 6:13 AM
SHADOW94
  • 6 POSTS
Ok guys Im gonna go with vats does anyone know the location of the vats box its not the computer cause i put a new computer in it and still the same thing i think the security light would be on if the bulb wasnt blown.so if anyone knows the location i would please let me know
Nov 10, 2009 at 5:33 AM
