1988 Chevy Camaro engine stalls when slowing down or at a s
KARR_4000
  • 1988 CHEVROLET CAMARO
Engine Mechanical problem
1988 Chevy Camaro V8 Two Wheel Drive Automatic
put new plugs wires dist and rotor on car stalls out when slowing down or at a complete stop acts like its flooded when trying to restart. What could be the problem could it be the speed sencor
Tuesday, December 1st, 2009 AT 3:52 PM
JDL
  • 16,098 POSTS
Welcome to the forum, if your fuel injected, I'd take the throttle-body off and clean it. Also check for codes?
Tuesday, December 1st, 2009 AT 3:58 PM
KARR_4000
Cleaned thottle-body new gasket and checked codes only code found was 24 speed senser any other ideas
Tuesday, December 1st, 2009 AT 8:52 PM
JDL
  • 16,098 POSTS
Usually if the problem occurs when braking, it's an idle air issue, closed throttle. The vss can effect idle air control. I think your headed in the right direction. Have a good day.
Wednesday, December 2nd, 2009 AT 9:30 AM
