1994 Chevy Camaro exhaust system mal-function
125,054 MILES • 6 CYL • 2WD • MANUAL
FIGUE04
  • 8 POSTS
Can, anyone please assit? Having problems with my vehicle's exhaust system. Change the cat, o2 sensors and the EGR valve on it to improve and lower the emmisions emmitted from the car. Within 3 days the cat went out and a new one was installed, again within 3 days the new cat went out. Car runs great and gives 20mpg, only thing bad on it is that there is smell of exhaust within the cabin and rattleing sound from the under the car and last; when car is coming to a stop a sound similar to a backfire. Please help. Thanks.
Feb 12, 2008 at 6:35 AM
2CARPRO JACK
  • 11,533 POSTS
If it has big exhaust leaks (smell in the car) then the mixture will read off to the o2 sensors and it could change the mixture to the point that it hurts the cats. How do you know the cats are going out?
Feb 12, 2008 at 7:33 AM
FIGUE04
  • 8 POSTS
I have been told that the cats are burning up.. due to the rattling sound coming from that area.. Would this be ture? or am I being told this in mistake?
Feb 12, 2008 at 8:35 AM
2CARPRO JACK
  • 11,533 POSTS
Could be, but I personally have never seen one go to pieces in 3 days. Might be pieces of the old one in the muffler. Are you using aftermarket cats?
Feb 12, 2008 at 9:37 AM
FIGUE04
  • 8 POSTS
I think they are after market cats. I will have them verify that there is no debris from the earlier cat within the pipes. Can this be preventing the vehicle from passing smog??
I have change sparks, spark plugs cables, o2 sensors, had the egr valve cleaned and PVC valve exchanged and still did not pass.
Feb 12, 2008 at 9:43 AM
2CARPRO JACK
  • 11,533 POSTS
Is the check engine light on? What part of the test is it failing?
Feb 12, 2008 at 11:08 PM
FIGUE04
  • 8 POSTS
according to the person doing the test, the emissions tests. bad egr, o2, and cat.....
Feb 13, 2008 at 1:29 AM
2CARPRO JACK
  • 11,533 POSTS
I need better info. He obviously is having a hard time here. If you cant give me the info let me know
Feb 13, 2008 at 1:48 AM
FIGUE04
  • 8 POSTS
Engine light does not come on or stay on. According to test location its is burning fuel to rich. Cat is good according to a most recent muffler shop just visited (yesterday).
Actions taken prior to smog test: Oil nad filter change, spark plugs and wires exhcnage for new ones, o2 sensors exhange, catalytic revised (rattling sound coming from within), heat sheilds secure.
Result: Technitian did not want to continue with the test due that vehicle, displaying various problems; o2 sensors, bad cat, egr, pvc valve all faulty.
I have since went back to the shop where all the exhanges had been made and requested that they be revised, anticipating a faulty piece of equipment. It all checked out and all were good.
Feb 14, 2008 at 7:26 AM
2CARPRO JACK
  • 11,533 POSTS
What are all the readings for the failed emission test?
Feb 14, 2008 at 7:44 AM
FIGUE04
  • 8 POSTS
NO (PPM)
15 mph: 692(max) 150(ave) 1566(meas)
25 mph: 711(max) 136(ave) 1621(meas)
This is the only portion of the tet that it has failed. I did take the vehicle to another Smopg shop (more trustworthy) recommended by local Chevy dealer. Hopefully this will give you a better undeerstanding of what needs top be done to my vehicle. Thanks
Feb 18, 2008 at 4:14 AM
2CARPRO JACK
  • 11,533 POSTS
Nox is EGR function. Good source vacuum at the EGR solenoid? If valve is pulled on manually with vacuum pump does the engine stumble to the point of almost stalling? If not the passages are plugged.If all ok, then I would go for the EGR control solenoid
Feb 18, 2008 at 10:28 AM
FIGUE04
  • 8 POSTS
EGR valve is electric, cannot perform a vacuum test on it. Or can a test on the vacuum be performed? EGR control solenoid? Where is it located on a 94 camaro?
Feb 22, 2008 at 7:54 AM
2CARPRO JACK
  • 11,533 POSTS
Electric doesnt have one...... might be a problem with the PCM
Feb 22, 2008 at 9:10 AM
