Computer problem
1994 Chevy Camaro 6 cyl Two Wheel Drive Automatic
cant get gas to the injectors replaced the fuel pump the filter
Wednesday, May 19th, 2010 AT 10:46 PM
MECHANIC
Check the computer injector driver circuit.
Wednesday, May 19th, 2010 AT 10:52 PM
SMITAY
MEMBER
How do check the injector driver circuit
Thursday, May 20th, 2010 AT 8:18 PM
MECHANIC
Get a noid lite at the auto parts store and hook it up on the injector wiring connector if the circuit driver is working it should be flashing
Thursday, May 20th, 2010 AT 10:20 PM
SMITAY
MEMBER
I try the noid lite and it flashed so clould it be the crank pos sensor
Saturday, May 29th, 2010 AT 7:19 PM
MECHANIC
Crank the engine over do you hear the injectors clicking?
Saturday, May 29th, 2010 AT 7:48 PM
SMITAY
MEMBER
Yes I hear the click
Saturday, May 29th, 2010 AT 10:21 PM
MECHANIC
Is the injectors spraying fuel-if not test the injectors.
Sunday, May 30th, 2010 AT 6:07 AM
SMITAY
MEMBER
How do I test the injector the injector are not working if I spray gas in the throttle body it will start but something is stoping the injector from spraying
