Computer problem
1993 Chevy Camaro 6 cyl Two Wheel Drive Manual
tried to pull codes and OBD l will not respond with code key inserted in the OBD
Thursday, May 6th, 2010 AT 6:09 PM
LEOMNR2008
MEMBER
If the ecm is not responding you need to make sure that the ecm is fully pluged in if it is than you probly have a bad ecm and will need to replace it.
