1992 Chevy Camaro V8 Two Wheel Drive Automatic
My 92 Camaro rs doesnt wanna start in cold weather and mostly when I start it, it has high oil pressure and idles rather high. It could use an oil change but could there be other problems I should check for? And also when I go to put it into gear the shifter seems loose or somethin. It doesnt click into place right and rarely ever goes into park. I almost have to slam the shifter up to get it into park. Could it be a problem with the column? Or should I look out for transmission problems?
SPONSORED LINKS
Thursday, February 5th, 2009 AT 11:57 AM
