We dropped the gas tank, replaced the fuel pump and strainer thinking that may have been the issue. Still nothing.
The tank keeps good pressure and the gas lines appear not to be clogged since the engine does run for a good period of time. The injectors had been replaced, the PCV and the EGR valves are fine and the engine is not giving any codes. We even checked for a vacuum leak and everything appears good.
Does anyone have any ideas? Any help would be appreciated.
Thanks
SPONSORED LINKS
Monday, April 17th, 2006 AT 4:53 PM
