1991 Chevy Camaro hey
LEE LOWMAN
Engine Performance problem
1991 Chevy Camaro 6 cyl Two Wheel Drive Automatic
what does it mean if my injecters do not pulse
Jul 23, 2009 at 6:15 AM
JDL
  • 16,098 POSTS
Hello, the injector has to have voltage and ground. The computer pulses the ground circuit to the injector, engine cranking.
if your having a problem with the injector/s, check for B+, key on. If the computer isn't grounding the injectors, one possible reason is no rpm signal.
Jul 23, 2009 at 6:33 AM
