1995 Chevy Camaro
1995 CHEVROLET CAMARO
NICKNICK09
Electrical problem
1995 Chevy Camaro 6 cyl Two Wheel Drive Automatic
i have a 95 chevy camaro and i am not getting any spark. any ideas
Dec 30, 2009 at 3:40 AM
ERNEST CLARK
  • 1,730 POSTS
If the engine cranks over but there's no spark, then r it could be, from simplest to hardest:
1) Crankshaft position sensor
2) Camshaft position sensor
3) Coil/Coil packs
4) Ignition control module
There's no way of telling this without interrogating your computer. (You have an OBD I system)
If you go to AutoZone or any other major parts dealer, they should allow you to use their scanner for free.
Once you get the trouble codes from the computer, ask them to give you the definitions.
This will tell you what's faulty, but not necessarily why. This information will give you a starting point.
Dec 31, 2009 at 5:18 AM
