1991 Chevy Camaro HELP
CAMARO V6
  • 1991 CHEVROLET CAMARO
  • 6 CYL
  • 187,000 MILES
CAN YOU CHANGE THE FUEL PUMP ON A CAMARO WITH OUT TAKEING THE GAS TANK DOWN
Friday, January 4th, 2008 AT 7:14 PM
DWTOOT
ONE MIGHT BE ABLE TO MOUNT AN EXTERNAL AFTER MARKET FUEL PUMP ON THE CAR AND PULL THE FUEL THROUGH THE STOCK FUEL PUMP AND FILTER OTHER WISE THE TANK NEEDS TO BE EMPTIED DROPPED THEN PUMP REPLACED. NOT TOO TOUGH A JOB BUT TIME CONSUMING. BE SURE TO DRAIN ALL FUEL!
Tuesday, January 29th, 2008 AT 5:17 AM
